Help!!! TRD rear sway bar problem.
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I got my TRD rear sway bar, part # PTR06-06990-10 for my 01 ES300.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Installation went well except the bar is 1/4in short. Basically, driver side mounting holes off by 1/4in. Pushed the other side to the max but didn't help at all.![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Any of 2001 ES300 has similar problem? Can't be defective bar right?![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
I don't want to spend another $200 for whiteline and pray.
Charley... im interested to know ... how much of a different the front swaybar made to ur handling?
i only upgraded my springs/struts/rear sway.. will be putting the tower brace on soon.
the strut bar and sway bar are two different things. the strut bbars connect the strut towers, the sway bars connect the lca. i think it made a difference, because its not like im drifting my car where i need to be concerned so much with oversteer understeer. but i do think it makes a somewhat difference.
btw, i have the whiteline fsb and rsb.
goodluck
Charley
goodluck
Charley
Thanks Charley....I got Whiteline rear sway bar & KYB shocks and King spring (OZ manufacturer)at the moment..... Im going to order the strut tower brace from Whiteline .... it take about 4 weeks on order ...do you remember the code ID from Whiteline for the front sb?
Took it off right after I posted here (got so mad). Compared the two sway bars next to each other, the TRD is definately shorter by 1/2in.
Is there anyone here has '01 ES300 with RSB upgrade? If so, please let me know the part #.
I am not sure if '01 has some changes or not but everything fit perfectly except 1/2 shorter.
First, defective NGK spark plug, know this. However, I can remove / reinstall all SIX spark plugs or remove / reinstall RSB in a less than 15min.
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
