1998 ES 300- Chk Engine Light
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I have problem with Chk Eng light. I went to Auto zone. They gave me 5 different code.
Code : p0100 p0110,p0330,p1410,p1411,,. I also went to couple other and they all say for thorough check could cost up to TWO hrs for diagnostic. Then I went to Lexus dealer. They recommended Mass air flow , Knock sensors and last thing replace O2 sensors. I am not sure how all three things goes at the same time. Can some one tell me better way to fix this one without paying $2500.
Thanks
Thanks
Thanks
Thanks
take your chances on the J-yard. or google around for the parts and see what you come up with.
Thnaks
But I am looking in to cleaning MAF sensor.Is ther any thread for how to clean MAF sensor. I found one site that shows how to for RX300 model. O2 sensor will be next. Is it possible this codes are on because I used fuel injector cleaner ? Chk Engine light came after I started using fuel injector.
Super Moderator
Thnaks
Yes, on fuel injector cleaner and check engine light. I have actually run a gas analysis test (a clone of an emissions test) before and after I put in some fuel injector cleaner (Techron) and you could see the difference, especially in HC (hydrocarbon) count. Wait until your next tank of gas to evaluate.
I'd also reset the battery (not just clearing the codes) and see what happens on the next tank of gas.
Generally, when those knock sensor codes pop up, they are the problem to tackle first. Those don't seem to go away from experience I have seen with others.
Thanks LEXMEX.
I also tried guranty pass emission test. That gas of tank is done. I have used Lucas fuel injector cleaner and lubricant. That gas tank is still running. I am going to clean MAF and then try reset battery. Hopefully it will work. Thanks for your help.
Super Moderator
My favorite fuel injector cleaner of the bunch has been the Redline Fuel System Cleaner (Pep Boys is the place I usually see it at), only about $8.
Here is an update on my lex. I cleaned MAF sensor, throtle air intake (was gunky). Then I checked code again. To my surprise only one code was left out of 5 different. Only code left was for Knock sensor. I was able to replaced that with my friend. I drove few miles, no chk eng. light. but when I went over 60 mph on highway light came back on. This time its insuficency of air. I believe may be one of the hose not connected ? Do you thing may be I need to drive certain miles before code disappear ? or this my be a new code ? I went for inspection with chk eng light reset. It failed, No codes but because it was reset and not enough data ? I need some help. I check all hoses, it seems all looks oK.
Sorry, I could not return here this weekend, Good news is all my codes gone now. I have to drive little bit then off for inspection. After replacing Knock sensor. I checked with Autozone for code and it was P0401. It has to do with EGR system. So I removed engine cover and checking all hoses and ther it was. One of the hose (small) was loose and part of the plastic tube was broken.I almost wanted to go back to Autozone and order that parts but then I decided to glue it, Let it dry and put that part back. and NO MORE CHK engine light coming back.I don,t know that part name but hose that come out of EGR valve and goes under engine cover. Apparently during knock sensor change somehow it broke. Does anyone know how many miles to drive before ECM data become valid for inspection ? I can not belive Lexus dealer wanted $ 2500 for repair and I got that problem fixed for $ 175. Also wants to thank to all of you that gave me confidence and information. Please keep up good work.
pcb1968
08-23-12 09:25 PM
