2003 ES300 Climate Control LED Burnt Out
I just noticed (tonight) that the switch that controls the passenger side temp and the switch that controls the "mode" on my climate control is not illuminating anymore. The LCD display, and the other switches still illuminate, just not those two switches. I looked at the threads that covered the issue of burned out LED's with older generations of ES models, but did not find any for the 02-06 models.
Has anyone else had this problem? If so, where did you get your replacement LED's? And how difficult would it be to remove the climate control display and re-solder the new LED's in for someone whose soldering experience is limited to soldering wires on relays and audio jacks. Thank you for any help/advice.
I haven't had mine pulled out, But im pretty sure it isn't an LED, But rather a small bulb, Like those used in some cluster assemblies. Just pull out the HVAC Assy, and pop the bulb out and get a replacement at the part store.
Does anyone know what I might be doing wrong?
Do I just need to pull harder or am I missing some other steps?
I tried searching, but did have any luck.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Im pretty sure it just pops out. Take a flat head screwdriver wrap it in a good cloth and try to stick it in the sides near the top portion to pry it out and overcome the clips.
1 Post
This link may help: https://www.clublexus.com/forums/sho...d.php?t=129035
- The Climate unit just pops out
- Mine was one bulb that I brought from Lexus for $8
cool thanks, I just got it out this morning and the dealer is going to have to order the bulb for me. I think I am going to go on and order them all since I will have out already.
hello frend but the problem you are having is most likely the unit it self , is it durk around the edges ????? let me now and if so it is the kristal board in the unit , i might have one
i have the same issue on my 03 ES300 as well
i just bought the bulbs from the lexus dealer (all 8) and im going to replace them this afternoon...
the climate control unit just pulls out of ther dash correct? i dont see any screws holding it in so i assume it just pulls out
Registered User
How much were these bulbs? And is the dealership the only place you can buy these?
Also, if bulbs are out on the stereo, is this the same procedure to have them working again?
