OBD error 420 - catalytic system failure
The engine-problem idiot light went on during a spin in the country - ES300, 1995. Turns out the OBD code is P0420 "Catalyst System Efficiency Below Threshold."
I replaced the cat converter recently after a mandated emissions test showed it to be faulty - and my gas consumption went smartly better. In light of various rusty parts in the exhaust system, to save money I just had the new generic converter welded in at the local muffler shop.
So does that mean it is an O2 sensor? Is there more than one sensor and/or any suggestions about what to replace first? Any need to hurry with the repair, other than pollution considerations?
Many thanks.
Ben
Many thanks.
Ben
The problem stems from you replacing the OEM cat w/ a generic. The Toyota ECU is very sensitive and will detect even the smallest of changes in readings from the O2 sensor. It doesn't necessarily mean your O2 sensor is bad. I had the same issue with my '98 ES. Replaced the cat, after so many engine cycles, damn CEL came on. I tried everything you could think of to get it to go out. The solution for me was wiring an O2 sensor bypass inline so as to fake out the ECU. I now get no more check engine light.
Thanks for insights about after-market cat converter, I gather you are both saying the same thing. Yuck.
For now, the service signal has been canceled. If it is the cat converter and not an O2 sensor, I guess I can live with the light re-appearing although that could possibly mask some other, more serious, issue.
I don't see why, but my average-route mileage went smartly down after the new cat converter was installed, like from under 20 mpg (12.3 L/100km)) to just under 24 mpg (10.9) (and in the summer when riding my bike lots, substantial loss to evaporation). Just a hint in the last tankfull that consumption is getting worse. Not certain of that fact or the diagnostic implications.
In 20 months I need an emissions re-test... car then 15 yrs old! In Ontario, there's a charitable exemption from meeting the standards: no work needs to be done if a careful diagnostic certifies that the owner would have to ante up more than $400 (which includes the cost of the diagnostic, I think) to fix it.
Again, thanks.
Again, thanks.
flyboyplo
05-09-14 08:30 AM
