Question about Moonroof
My monroof stop working last night on my ES300 and I was wondering what could be the problem. The switch does not work at all neither opening or tilting the moonroof. It's just dead. Could it be just a bad switch or fuse? Thanks for any help.
i have the same problem from time to time. when u push the button, do u hear a relay 'click' near the button? if so the motor is going, if u really wanna risk it and open up the sun roof, u can take down the center glassesholder/map light by removing the 3 screws holding it up there (two visible when u open the glasses holder and the other visible after gently removing (prying) the map light lens with a flathead. After you take that out, u can see the motor for the moon/sun roof, take a metal object and tap on it, or bang, but not too hard because if u punch it as hard as possible like me, you'll put 2 little outgoing dents in ur roof....(stupid move but it was raining and i had to close it)
g-luck im probably going to replace the motor for mine soon and possibly make a DIY.
CEO714
02-01-14 10:16 AM
