Question about rim and tire fitment
I was wondering if anyone has done anything 18x8 +43 and 18x9 +38 in the rear with the car lowered. Would these fit my car without any problems or fender rolling? and what size tires would be good for them? maybe if I strech my tires?? how big of a strech??
Any advice would help.. Thanks.
your concern shouldn't be stretched tires, but with those widths and offsets, you will more than likely rub the strut housing. highest width you can go on a +43 offset is 7.5 i believe. any wider is going to rub guaranteed. with a 9 width, you're going to have to run really aggressive offsets, around +25 or so.
If you're looking to run aggressive wheels, run an 8.5 width with an offset b/t +20 and +25. That should give you pretty close to fender flush fit. If you run a 9 width, then you will have to run mad camber with a +23 offset to get it flush.
As far as stretched tires go, if you're looking to get it flush, go with a 205 on the 8.5 and a 215 on the 9 and slam the car
Don't screw around with 205 or 215 series tires. You want 225/40/18 all around it will keep your speedo accurate and won't effect your fit. As far as the rims I agree that they will fit with a spacer but your gonna have to totally delete the rear fender not just grind it a little and your going to have to roll the fronts as well.
Front too?? The front is 18x8 +43 though.. I would like them as flush as possible. I just rolled the rear but I guess if I need the fronts I will do those 2morrow. I dont know what size tires I would need to get and I dont want to just try tire sizes and see what fits best thats why I am asking on here.
if you want a reference on tires sizes as far as stretching and clearance goes, look in the VIP subforum. Search and there should be a thread on stretched tires. I would definitely run a 205 on the 8 and a 215 on the 9. However, I would opt to just run an 8.5 width all the way around. You really aren't gaining anything by running a staggered setup. good luck.
