Check engine light
Check engine light
Have a 92 es 300 the check engine light is on with te1 e1 jumped check engine light stays on in dash. Trying to find an answer to this. Thanks
Yeah, I wonder if there is some way to disable it so it won't keep the traction control off...
We have a 99 ES that has a P/N safety switch code and an evap/emissions (charcoal canister) code, which neither of them amount to a hill of beans. We don't have an emissions inspect in AR and the car still gets 30 mpg hwy.
I do seem to smell the exhaust running a little rich when sitting at a light with the air set to outside air instead of recirc, but that may be due to the slight exh. leak that happened due to a worn out torque strut (like the motor mount thing that keeps the motor from torquing back and forth too much) that flexed the flex joint and kind of wore out the exhaust gaskets... ---
pcb1968
08-23-12 09:25 PM
1badceli
Performance & Maintenance
01-15-06 07:25 PM
