93 es300 NO HEAT
Old 12-20-08, 09:08 PM
Darylls
Darylls's Avatar
Angry 93 es300 NO HEAT
I just bought a 93 es300 it has no heat i went to change the tstat and found there was none so i put one in still no heat.I found a valve on the driver side by firewall guessing heater control valve the cable that operates it was off so i moved the valve by hand still no heat.Should i try bypassing that valve?? How can i tell if the heater core is clogged?? Please Help 20 degrees with 2 kids no heat stinks Thanks
Old 12-22-08, 05:43 AM
GEORGE_JET
GEORGE_JET's Avatar
Place the climate control into diagnostic mode. Press and hold the RECIRC/OUTSIDE air rocker switch, and the AUTO button at the same time. Then turn on the key. The climate control lights will flash 4 times, it will then flash any stored codes. (originally I thought the front/rear switches placed it into diag, but I tried this on my car and found that I was wrong.)
Old 01-22-09, 10:37 AM
big basset
big basset's Avatar
check water level mine was really low.. and there was no heat
americk22
SC- 1st Gen (1992-2000)
16
01-25-23 07:34 AM
BlaineyB
Performance & Maintenance
03-15-12 10:35 PM
JohnEd
12-20-08 09:16 AM
ERILUDE
12-05-06 07:55 PM
Quick Reply: 93 es300 NO HEAT
