Coolant equivalents?
Hello guys, the ppl at autozone were to uneducated to answer my question and the nearest Lexus/Toyota dealer is 60miles from me so i figured i could come and ask the basis here. So, i have a 2000 Es300(VMI or w/e version of the engine) and my coolant is on low, whats some equivalent coolant can i get for "TOYOTA Long Life Coolant"?
which i still would need to go to a toyota/lexus dealer to buy... im asking for more generic ones like the dexcools from autozone.. which one is the best one? pic/product # any info would be nice
edit: im not being a smartass.. my bad if it sounds that way
No that is not correct...
You should not mix Toyota 'Long Life' coolant (Red) with Toyota Super Long Life coolant (Pink) already....trust me, my Lexus dealer refused to put it in my previous 2001 ES 300....they told me they are not compatible.
mild....I would suggest making the trip (put some water in the coolant recovery tank) & make the trip to the Lexus/Toyota dealer.....do you know if you are due for a coolant flush anyways as opposed to a 'top up'?
How low are you on coolant?
its just below the Low line aaaand i dont need coolant flush i just need to top it up so it wont suck in air, thats my major concern.. the coolant looks orange/red in color... my father says there a green/yellow coolant thats compatible with all other coolants and it can be mixed but i dont wanna **** up with my car u kno what i mean
My suggestion was to kill two+ birds with one stone, have a coolant flush with Toyota Long Life (Red) coolant (bring them a 1 gallon jug of distilled water - about a buck at your supermarket), & at the same time have the dealer inspect everything to see if there are any noticable leaks & possible related issues....they will burp the system & your good for a number of years.
The coolant level you mention is not that critical...you can simply top it up with water only (it's a very small amount - check your owners manual to varify the total capacity to understand what I mean) & monitor the level over the next week to 10 days.
I would not mix different brands of coolants on your ES if I were you (I am very aware that other coolants purchased at auto parts stores claim to be compatible & strongly advise against it). Check your owners manual (do not use Dexcool or equivalent coolant).
Long term...top up with water & make the 60 mile trip to the dealer get a coolant flush done (should be only about $100 or in the ballpark).....ask them for the remaining new coolant (should be about a half gallon jug) so you can keep it at home in case you need to top off.
alright man, thanks for the help i think ill just do that before school starts next week cuz i drive 60miles daily to and from school.. thanks for the help again
i have a 93 es lastweek for like an entire week my radiator hose had a gash i out some duck tape and it worked fine untill it went very low on water and started to steam and stoped cooling the car all together, the temperture went up but never hit red
anyways now i keep hearing sucking noise and the reservore is allways empty after a day of drivinh and i fill it up all the way
How would a person know if they have Toyota red or pink in their system? Red diluted 50/50 should be pink anyway, and if they're not compatible, the system would have to be completely flushed until clear before switching from one to the other.
You won't really do anything if your simply topping up your coolant recovery tank on the L to F mark.....as a temporary fix.....but I would not do a complete flush with it.
I stress to people to read their owners manuals carefully......this will prevent problems & $$$ in possible repairs. A proper coolant flush at your Lexus/Toyota dealer should be in the $100 range give or take (or buy the correct amount....usually a 1 gallon jug of Toyota coolant & a 1 gallon jug of distilled water & take it to your trusted auto shop...fluid capacities are in the owners manual). Why take a chance?
i was watching the 993 owners video and in there it was saying its ok for oild temperature to go as long as it dosent go into red
http://www.youtube.com/watch?v=Xdi9kwx9hjs watch from 3.45
