Engine misfire? Not sure need help!!!
Old 01-18-09, 07:48 PM
Ariyanna
Ariyanna's Avatar
ok my car is getting worse with the engine to shake more than pulsate now and i have no clue what it is any guidance would help thanks
Old 01-18-09, 09:29 PM
Lexmex
Super Moderator
Lexmex's Avatar
How is your rpm at idle and does it fluctuate when you have this pulsation?
Old 01-18-09, 09:34 PM
Ariyanna
Ariyanna's Avatar
Yes at idle why??
Old 01-18-09, 10:05 PM
Lexmex
Super Moderator
Lexmex's Avatar
Originally Posted by Ariyanna
Yes at idle why??
That's usually a symptom of the IACV gone awry. I've had that before with my RX300.
Old 01-18-09, 10:21 PM
Ariyanna
Ariyanna's Avatar
Should I go in clean it will that fix my problem???
Old 01-18-09, 10:23 PM
Lexmex
Super Moderator
Lexmex's Avatar
That's a likely possibility. Another remote one is an exhaust leak near one of the two A/F sensors on the exhaust manifold, though that is less pronounced (a.k.a. not as well felt).
Old 01-18-09, 11:03 PM
Ariyanna
Ariyanna's Avatar
interesting I had my both my flex joints on my flex pipe replaced about two months ago I will take it back to the shop and have them see if it has a leak near there, but today i will go in and clean the IVAC
P.S. I really appreciate the help Lexmex thank you
Old 01-19-09, 01:04 PM
Ariyanna
Ariyanna's Avatar
OK problem fixed it was my IACV which was dirty with carbon and even the throttle plate was nice and black so I cleaned both and also cleaned the inside of the intake as well and now the car turns over smooth as silk and no more pulsating feel
Old 01-19-09, 02:09 PM
Ariyanna
Ariyanna's Avatar
Spoke to soon I went for a test drive and my check engine light came on and the engine started to shake light started to flash went to auto zone and they told me that cylinder number two is misfiring. What did I do?? All I did was clean the IACV and throttle body, what could have caused this or is there a bad spark plug or wires HELP PLEASE!
Old 01-19-09, 04:04 PM
Ariyanna
Ariyanna's Avatar
Bump...............
Old 01-19-09, 05:31 PM
92ES5sp
92ES5sp's Avatar
Maybe whatever you used to clean the TB fouled out the plug. #2 is the front one on the left. Take out the plug and check it out.
Old 01-19-09, 05:34 PM
Ariyanna
Ariyanna's Avatar
Yeah cause I bought a new coil and its still doing it you think if I clean it that it will solve the problem?? Cause I used STP throttle cleaner which is O2 and catalytic safe. I cleaned the throttle body and sprayed cleaner inside the intake , scrubbed with a brush, dried it with a rag and put it back together. Thats all I did
Old 01-20-09, 01:58 PM
Ariyanna
Ariyanna's Avatar
SUCCESS PEOPLE My car had a bad fuel injecter and I went bought a new one and replaced it and now my car purrs like a kitten and drives like a LS I mean like a ES
Old 01-20-09, 04:55 PM
dallison
dallison's Avatar
nice, at least you were in the right area
Lelio
10-15-18 01:12 PM
chenxingha
RX - 1st Gen (1999-2003)
04-21-18 11:04 AM
1WILLY1
SC- 1st Gen (1992-2000)
13
07-26-10 07:52 PM
Alexusoftime
Performance
05-18-10 04:37 PM
eddiej
11-18-08 08:22 PM
Quick Reply: Engine misfire? Not sure need help!!!
