newbie to site and sqeaking steering wheel
My 3es300 steering wheel sqeaks especially when cold. Noise sounds like plastic on plastic or leather. Not metal. Noise comes from right behind the steering wheel. Slow turn low tone. Faster turn higher tone. I can almost make it talk. lol. Should I take wheel off and look? I found a thread on removing steering wheel but could not get the pis. Do I need html on or is there another problem?
I've got the same issue with my steering wheel donnie boy. You are right, turn the wheel just slow enough or fast and its almost like the car is talking to you! Im tempted to look take apart the steering wheel and see if I can fix the issue (maybe apply some silicon spray?!?) but i havent had the time.
Doesn't the WD-40 drip down all over you and the floor?
However, I'm willing to take one for the team. Tomorrow, I will post results///
Oh, and on my original post I meant "pics".. very embarrassed.
Better download IEspell checker
when you spray the wd-40, you have to move your head around so that the wd-40 wont spill on ur face...But the wd-40 will drip on the floor so I recommend you put a piece of cardboard or any other material to cover the floor. I will provide the pics asap for everyone....And again, I did this and this fixed my problem...This was recommended to me by my mechanic...He said occasionally, the steering components get a little rusty or dirty and they start to make the squeeky noise....you have to apply wd-40 for it to loosen.
I'm done.. got head down by brake and turned wheel. I heard it and saw it immediately.
My sqeek was coming right from the point where the steering shaft goes through the floor board. The shaft is coupled with a rubber bushing and it meets a rubber gasket.
I WD-40ed it. I hope the petroleums dont harm the rubber. There was no warning on the can. Maybe a lithium might be better but, WD-40 did the job. I did put down a rag to catch the drips. I did not need to spray back up towards the wheel. I will try to post pics. Thanks hotlexus
Hey 99es300, where did you purchase the led lights for the corner, reverse, interior etc etc. I would like to purchase those too for my 99es300. Are they good quality? Cause some are not good quality and die out pretty quick. Let me know. Thanks
alexamparo
10-12-02 03:36 PM
