1999 ES300- trouble programming keyless entry-please help!
i recd the new keyless device, and used the directions, once i got to the part where i had to press the LOCK button on the new device- nothing happened!- i even changed the battery in it too.....
i have tried several times according to the directions, and even tried with the door open and door closed the whole time....
i am really frustrated and need help![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
PLEASE!!!
PLEASE!!!
Try it again. It works if you do it right. Read carefully, I missed a couple things the first time I did it.
1. Sit in the driver's seat and lock all the doors.
2. Unlock and open the driver's door.
3. Insert the key into the ignition and remove it (don't turn it...just remove it).
4. Using the MANUAL lock switch on the driver's door, lock and unlock the door 5 times.
5. Close the door.
6. Open the door.
7. Lock and unlock the driver's door 5 times (with the power switch).
8. Insert the key into the ignition and turn it to the "ON" position.
9. Remove the key.
10.The driver's door will now lock and unlock itself one time.
11.Press and hold the "LOCK" button on the key fob for at least 1 second.
12.Close the driver's door.
13.Open the driver's door.
14.Press and hold the "LOCK" button on the key fob for at least one second.
15.Close the driver's door.
16.Press and hold the "LOCK" button on the key fob. The door will lock.
17.Press and hold the "LOCK" button on the key fob again. The door will unlock.
5. Close the door.
6. Open the door.
9. Remove the key.
Kburches
15
01-26-23 11:41 AM
kino1161OL
GS - 1st Gen (1993-1997)
19
11-07-08 02:12 PM
