1997 Well maintaned
1997 Well maintaned
With all this Cold Weather latley I am having promblems at Start up . The car will start up and then Stall. I have to restart with my foot on the gas for a few secounds. Any suggestions?
Try cleaning the fuel injectors with fuel injector cleaner. Also clean your throttle body.
Battery is new , From Sears . Water pump is not due to be changed yet. Fuel cleaner is run every thru every 3,000miles . Throtle body is cleaned every 6,000 miles. Only 93 gas is run in the Vehicle. It does this Every day now. It no longer idles High like it should when you first start the vehichle. The ECU has been reset with no results. I have no Codes. O2 sensors are working fine per Scanner information.
Spark plugs . wires .coil packs have less than 10,000 miles on them. where is the idle are control valve? Any pics of location and instructions on how to clean? Thanks
mungrin
Performance & Maintenance
01-01-14 01:14 PM
