Vacuum hoses.
so previously on episode, my car died on me alot. We have an update. its totally good, i found out i had a split vacuum hose , a few months back i had my belts replaced, and to my suprise today once i fixed the one vacuum hose, i noticed another hose, JUST EFFIN SITTING THERE. I have no damn clue what this hose goes to or what it is for, if anyone can plz plz help me, i really need it lol.
i have attached a picture below for your viewing pleasure. the white circled object i have no idea what it is, and the burnt orange circled object i need to know where that hose goes.
![](http://c3.ac-images.myspacecdn.com/images02/19/l_d9a821e4629a491c83bef6d4ffc4d076.jpg)
Ok, the hose that you have the orange circle around goes to a valve that is located between the intake manifold, and the firewall (app the center of the manifold). I believe that it is part of the evap system. The other connection (with the white circle should be capped off).
Have you located the fitting between the firewall and intake? I have looked up the evap system and no longer believe that this is part of it. I confident the hose goes there, my car appears to be un-modified (at thhs time) When I get a little free time I will look a little closer at it. Good luck
yeah i was under the hood for like 30 minutes and i couldnt find nor feel where it went >.< i wish i knew more about cars. ill have to take a better look at it tomorrow during my lunch break
