Can anyone recommend...?
Sup guys,
first of all i have a 2001 platinum series es300 and i was thinking of changing the fog light bulbs to yellow ones. can anyone recommend a good bulb with the wattage and where i can buy, and if possible price? im looking for non-hid but hid is ok too
thanks!
thanks!
Here is a pic. This was during the pre-burn-in stage though, which means that the fogs were relatively new (less than 1 hour) so it didn't get to its true color yet. I found that it needed at least 2 hours to burn into its true color. Its much darker now but I've replaced my fogs with projector fogs at the moment. Currently checking to see if I should retrofit HIDs in there again though
The fogs are DDM and the low beams are mobileHID. I use my fogs every single night
6000k low, 3000k fogs
On my 02 ES I put in PIAA Ion Crystal bulbs. Your current bulb configuration is a 55w H3. You can get the H3 Ion Crystals for about $30 each or even cheaper on eBay. In the ES they gave off a nice yellow color. They do not do so well in the 9006 format for my GS.
steviej
steviej
steviej
steviej
so the ones you have are hid? cause im mainly looking for non hid. if its non hid then im pretty sure ill get the piaas...thanks steviej
