2002 ES300 Rear Main Seal
Just noticed a smell and had it checked at a local shop.
They said it looks like a rear main seal.
Are there any options other than pulling the trans?
Looks like a big hour job.
Dysfunctional Veteran
Ummm...no. i wish there was, but unfortunately the "Rear Main seal" is at the "Back" (trans side) of the engine. It seals the main (crank) and keeps it from leaking.
$800-$1200 fix depending where you are and whose doing it.
Super Moderator
http://www.liqui-moly.de/liquimoly/p...id/e_2501.html
Another one that is of note is the one from Bar's, http://www.barsproducts.com/1050.htm and that's available at a lot of auto parts stores, like AutoZone
they will leak if the oil isn't changed enough, or if the oil level is too high, or
wear and tear. alot of stressed out[how did you drive it] engine will leak too
barr's does work on a lot of cases, but only do it if you don't love the car enough to fix it properly
onderdonk
02-07-09 07:28 AM
