tps setting on 93 es300 5 speed
Whats up everybody. I was wondering what the tps (throttle position sensor) should be set at i got a reading with the ignition on it was .58 should it be closer to 1 volt at full throttle it read 3.86 volts it is adjustable the reason i'm asking is i'm going to run nitrous and the tps reading has to be at 4.20 volts at full throttle in order to work i can adjust it to that but i dont know if the car is going to run different. Thanks
