dreaded white smoke, 93 ES300
Ok, well if you have been following my posts regarding my engine and getting it on the step, you know what I have been through, just when everything was going great, no codes, no lites, gas mileage appearing to be good, this afternoon the CEL was back, along with a noticable miss. Drove it home, keeping the idle up, 1500 or so, watching the temp. guage like a hawk..I got home ok, well, I decided to let the engine cool a bit before doing anything else, so I worked on another project for a few hours, I went back to troubleshooting the miss, the only code was 55, knock sensor not working, but I noticed a distinct odor of gasoline, so I looked really hard for any sign of a leak, then I noticed a puddle on the driveway.... hmmmmmmm had my GF run the engine while I looked to see where the gas was coming from, about then I noticed the exhuaust.....white smoke.....sooooooooooo my guess is a blown headgasket worst case, best case is a dead sparkplug..... with fuel injection, the dead cyl. is still getting gas, just not doing anything with it....so the white smoke. Tomorrow is pull the plugs, check the compression and go from there..... the only real puzzle is where is the cas coming from, my supposistion is that the unburned gas is exiting from the blown head gasket.... or ...........only time will tell, or maybe the shadow knows.
any comments or adivice is solicited....
thanks
capn
thanks
capn
As it turns out there was much more, I was dripping gas, and had to figure out why. I was able to ascertain that the problem was caused by a constant injection into one of the cyls. The problem with the injector was because there was a constant ground from the ECU to the injector. Under normal conditions B+ (12VDC) is applied to all the injectors whenever the key is on. The ECU grounds the other wire, completing the circuit, causing the injector to fire. My problem was that as soon as the key was turned on the injector was open, duping raw gas into the cyl. I got a new ECU, which solved the injector problem. But read on, as it now gets very interesting... While I had the air chamber off to replace the cyl. head cover gasket, I also decided to change the plugs. I was going to use NGK Iridium plugs, but the local Advance Autoparts did not have them in stock, also the Bosch plugs were on sale, so I got 6 Bosch Platinum +2 plugs, I installed them, re-assembled the engine and was rewarded with a smooth Idle, No CEL, and no misfires. All was going well for 1 day, then suddenly with no warning the CEL came on, the engine barely idled, and finally died, I had the car towed to my mechanic, thinking that maybe a wire went bad, (they were just replaced a few days before), he began to trouble shoot the engine. after lots of investigation, measuring the resistance of the wires, checking the spark, and finally measuring the resistance of the individual plugs as a last ditch test. Surprise of surprise, two of the 6 brand new Bosch Platinum +2 were defective, no continuity from the tip to the cap. So we went to Advance to exchange the plugs for two new ones, and being suspicious of the plugs decided to test the new ones before purchase, the store only had 2 left of the Bosch, we checked them both, and they too were open from tip to cap...... so I exchanged the 6 Bosch plugs for NGK iridium plugs....my mechanic explained that had we driven the car for some time we would have loaded the Cat with raw gas, washed the oil from the walls of the effected cyls. and possibly damaged the O2 sensor for the rear bank. I am writing to Bosch to complain, asking for damages, (compensation for towing the car and having to have it repaired). I was wondering if anyone else has had a similar problem with the Bosch Plug. One of the reasons I felt comfortable using Bosch plugs is that they are made in Germany, (which up til now imho = superior quality, and I have have used them for 100's of thousands of miles driving VW Buses.... roughly 700k miles in 4 different VW's. On last cautionary note, because the injector was constantly flooding the cyl. I was dripping gas, I did not want to run the engine with this situation, so to try and find the source of the fuel, I engergized the fuel pump by jumping B+ to FP in DLC1 iaw the FSM. I let the pump run, did not see any leak, so I decided to take a chance and start the engine and try and see where the fuel was coming from. I removed the jumper, and hit the starter, and wow, it just clicked......what had happend was that the faulty ECU filled the cyl. with fuel, causing a hydraulic lock (liquids cannot be compressed). After many expletives, I pulled the plugs one by one, hoping the problem was in the front 3, of course not, it was in the back 3, number 3 to be exact. With the pugs out, I turned on the fuel pump and could hear the gas being sprayed into the cyl. This is when I figured out that the injector was stuck, I unplugged the injector, and it quit, so I then analyzed the problem and learned that the ECU was grounding the injector causing it to stay on. Fortuneately the piston was close to TDC, and I did not damage the engine, I could have bent a rod, or blown the head gasket. Whew! Wonder if anyone has had a similar problem. Oh yeah when I got the engine back to the way the Toyota engineers designed it it ran like a clock, except for billowing white smoke from the exhaust, after a few minutes of running the smoke slowly diminished, and now all is normal... my thought is that the cat/exhaust system was loaded with raw gas, and I had to burn it out.....also before I started the engine I changed the oil as it was contaminated with fuel, and I also poured some oil into the #3 cyl to replace the oil washed from the cyl. walls when the plug was misfiring,,, all in all it was a very educational, frustrating and stressful couple of day
oh snap, my car just started missing real bad and spitting thick white gas smelling smoke...again.
two years ago it did the same thing, had to replace the computer. its not throwing any codes this time. hmmm
3 hrs later, replaced my ecm, original number was 89661-33181 and i replaced it with a 89661-33180. replaced my spark plugs and she runs fine. it took 30 mins idling to bake off all the soot and gas from the exhaust but theres no more smoke and the idle is much smoother, even than prior to the missing. hope this works.
Jrsygrl8
09-11-17 10:30 AM
ivanito
05-02-12 09:49 AM
