loose maf? or maf need cleaning?
Old 03-25-09, 10:27 PM
saiyanL4
saiyanL4's Avatar
Default loose maf? or maf need cleaning?
hey guys,
im new here and just need some advise on what to do.
ive come to realise that there is something wrong the my maf sensor on the airbox. i noticed this when i pulled out the air box to check the filter to see if it needed replacing. after putting everything back together and starting the car it seemed like the engine was struggling to stay running. thats when i touched the maf and notice the engine running back to normal. so as the engine runs when i push down on the maf the engine sounds like its gona stall. im not sure if it just needs cleaning or if i need to either try to fix it or replace it. any1 have this prob please let me know.
oh ye this might seem very noob but how exactly do u you clean the maf?
ive seach on it and found a few threads but im still not sure how to do it.
theres no tutorial on it? :/ ohhh btw ive got a 96 es300 (windom)
cheers
bruce
Old 03-26-09, 06:00 AM
mmatheny
mmatheny's Avatar
Check the connector - might either be loose or have a broken wire.
Old 03-26-09, 07:09 AM
saiyanL4
saiyanL4's Avatar
i think it is loose but how do i fix it?
do i have to open up the whole thing?
the maf on my es300 has all these wires connected to it so i cannot just pull it out.
ill have to pry open it on the side where it is glued in. not sure if i should cause i dont want to brake it. :/
Old 03-26-09, 08:38 AM
mmatheny
mmatheny's Avatar
Try slightly pulling on the wires one at a time, and maybe you can isolate the bad wire. Most of the time, the wire will break inside the insulation right where it goes into the connector, and you won't see the break from the outside.
I had a cable going to the distributor on a 91 Dodge Dynasty that was this way - I dug into the sealant, stripped the wire, and resoldered it and put a piece of shrink tubing over it - the reseal it with RTV. (silicone - Room Temperature Vulcanizer)
Old 03-26-09, 05:50 PM
saiyanL4
saiyanL4's Avatar
cheers for the info guys ill try to clean it 1st b4 i pull it apart.
maybe it just needs some cleaning.
Old 03-29-09, 06:58 AM
saiyanL4
saiyanL4's Avatar
yo guys finally pulled it apart 2day worried somefin would go wrong but all has gone very well i must say. opened it up and found the bad connection fix it up by bending 1 of the metal strips back into place. didnt know it was that easy but it was.
Old 03-29-09, 05:33 PM
mmatheny
mmatheny's Avatar
Cool beans!
MattJO
GX - 1st Gen (2003-2009)
04-04-17 11:18 AM
AC1984
Performance & Maintenance
31
06-10-14 01:11 PM
Dereke
42
01-23-09 03:02 AM
sliva001
01-20-07 07:45 PM
Lexs400
11-16-04 12:45 PM
Quick Reply: loose maf? or maf need cleaning?
