Rubbing
Old 03-27-09, 08:24 PM
RikerC
RikerC's Avatar
Default Rubbing
I have a 97 es300. I put 20in niche rims on and only the back 2 rub. What's the alternatives to fix this problem??
Old 03-27-09, 08:26 PM
Choas
Choas's Avatar
Bad idea in the first place most 20's are going to be too wide. Whats the size and offset of the rims and what size tires do you have.
Old 03-30-09, 09:16 PM
Choas
Choas's Avatar
4th gen is diff tho plus he didn't give us offset or width
Old 03-30-09, 10:34 PM
Lazy
Lazy's Avatar
Depending on offset and width you can roll your fender to help. If that doesn't work you can try to cut the whole piece off or pull your fender. If you still need more then its time to go WIDEBODY!!! haha.. I don't know about 20's on an ES but whatever floats your boat haha..
tOnerz
tOnerz's Avatar
i put spacers in from kragen ($20) and they only rub with 4+ people. 225/35/20 tires
Old 03-31-09, 05:27 PM
Slooooooow
Regional Officer - NTL
Slooooooow's Avatar
Cool
Wow. Well if you're into the raised DUBs look, you've certainly accomplished it.
/Insert obligatory "It's your car/to each his own" text here/
gs300lexus
02-09-16 09:10 AM
Bigwun07
04-11-09 06:16 PM
Tank
03-29-07 04:51 PM
Seize
Wheels, Tires & Brakes Forum
12
04-11-05 09:36 PM
MCV20
17
02-21-03 08:29 AM
Quick Reply: Rubbing
