Just back from service -Which of these items can I do myself
Old 03-31-09, 01:54 AM
draco
draco's Avatar
Default Just back from service -Which of these items can I do myself
Well my car has gone in for it's first service since I have owned it. To date, nothing has gone wrong with the car and it has been plodding along without a sign of trouble. No visible oil leaks on the garage floor, no overheating, just working away being smooth and quiet. After the service, this is what the techs have recommended be done due to some faults they have found:
* Timing Belt and Oil Seal require replacement (timing belt because the oil seal is leaking hence timing belt would get wet) - About $AUS500 (Australian Dollars).
* Engine Sump is leaking so need to replace the gasket - About $AUS200.
* Auto Trans pan leaking oil
* Rocker Cover gaskets leaking oil
* Power Steering Service required.
* Trans flush required - a bit cautious on this given I have heard stories on here about the trans flush being done and then the trans ceases requiring a replacement.
* Both CV shafts require replacement (recommended as the CV joints are dry, but they make no noise and the boots have gone).
Can any of this be done at home for nowhere near the above costs (total excluding the trans and power steering service is just over $AUS2000.
Old 03-31-09, 05:18 AM
llcoolpass
llcoolpass's Avatar
sump aka the oil pan
rocker cover aka the timing cover
all that can be done in your driveway or a garage in one day
the trans flush is not something you can do. but you can do a fluid change and that is safe to do for transmission longevity. transflush if you took it somewhere to do is not smart unless you did it every 30 k miles since new. after a long time not doing it ... it is a bad idea.
Old 03-31-09, 05:23 AM
draco
draco's Avatar
My car is on higher mileage - 208000km's. It's a Gen 3 (97-01) so has the 1MZ-FE. Any instructions, DIY's for this stuff? Have started searching the forum but not found anything yet. Might even look at the Toyota forums to see if anyone has done some of these steps on a 1MZ-FE equipped Camry LOL!
Old 03-31-09, 05:29 AM
BDSL
BDSL's Avatar
Download a shop service manual and learn to do it yourself.
Thats how I did it.
Old 03-31-09, 05:49 AM
mmatheny
mmatheny's Avatar
I've been looking for a shop service manual for this gen - can you point me in the correct direction?
Old 03-31-09, 06:08 AM
draco
draco's Avatar
BDSL - any idea where I can download a shop service manual?
Old 03-31-09, 07:12 AM
draco
draco's Avatar
Bit of browsing on the web and came across these 2 links:
http://pdftown.com/Toyota-Lexus-ES-Service-Manual.html which links to
http://rapidshare.com/users/BQTCHWhttp://rapidshare.com/users/BQTCHW.
It's a 40Mb download, so will see what this is like when done. The file name suggests that it is a FSM - Full Service Manual. I will update this thread after I have downloaded it and checked it all out.
Old 03-31-09, 07:33 AM
llcoolpass
llcoolpass's Avatar
lol the 97 fsm is on the web now , too?
Old 03-31-09, 07:47 AM
draco
draco's Avatar
Well I downloaded to and OMG! The information, the information!!! Explosion diagrams, instructions on how to do this and take that out. Above links confirmed for the FSM.
Old 03-31-09, 08:52 AM
mmatheny
mmatheny's Avatar
Thanx, Draco! I have searched and searched, all dead ends. Was looking for 2001 - didn't think about looking for 1997 (same gen!)!
Old 03-31-09, 11:37 AM
BDSL
BDSL's Avatar
That was the webpage I used to download my service manual.
Good luck boys.
Old 03-31-09, 11:48 AM
masboy
masboy's Avatar
what's the password to download ?
got this :
You want to access the LinkList of PDFTOWN.COM. It is password protected.
lexus es
any Service manual for 03 ES300 ??
Old 03-31-09, 01:18 PM
Jewel707
Jewel707's Avatar
So doing a tranny flush isnt recommended? Im not sure if the previous owner has done it at all....should i just stick with a drain and refill?
Old 03-31-09, 01:59 PM
Jewel707
Jewel707's Avatar
Has anyone downloaded the FSM already from rapidshare? I was downloading it and the file got corrupted or something and now rapidshare wont let me download again. If any one has it for the 97-up i would really appreciate it. Thanks!
Old 03-31-09, 07:12 PM
draco
draco's Avatar
got this :
You will notice at the URL http://pdftown.com/Toyota-Lexus-ES-Service-Manual.html , before you click on download there is a bit of small text down the bottom that tells you the password
I think it is pdftown.com from memory.
Jewel it's a 40Mb file, so hard to host all at once. The file is made up of numerous PDF's broken into different sections, so I guess each PDF could be sent individually. Try clearing your IE cache on your PC and give it another shot.
Quick Reply: Just back from service -Which of these items can I do myself
