Need advice
I have a 96 es300 and recently purchased headlight assembly kit for the drivers side. The kit fits perfectly but I found out that the turn signal socket does not match the original on the passenger side. The turn signal sockets requires a Double filament not a single filament. The double filament will not even fit into the existing slot. Is there anything I can do?
Thanks
Thanks
go to a junk yard and buy the sockets you need over there, plenty of 92to 96 es300's cost is very low ($10 to 20) if you want to spend a fortune goto a dealer price would range from 180 to 300 depending on the amount of time spent on your car.......
good luck!!
good luck!!
johnnyt
02-10-05 05:52 AM
