Sea Foam questions
I have a 1998 ES 300 with only 40,000 miles on it. Is sea foam appropriate with the low mileage. Also, if spray sea foam is used in the intake manifold how do I judge how much on to use? Thanks for your reply.
usually it's the whole can of that
and that car is not going to mind a decarbon procedure at 40K miles and 11 years. just make sure you follow the CORRECT procedure which is a little bit involved and REQUIRES and oil change.
if you searched, you would have found it. if you search, you will find the correct procedure
