dim instrument panel on 2002 es 300
Old 03-13-02, 07:41 PM
i112151
i112151's Avatar
Angry dim instrument panel on 2002 es 300
service manager says its normal! anyone have any ideas?
Old 03-14-02, 06:51 AM
lowPhaT
lowPhaT's Avatar
I have a 2002 and don't have a problem with a dim instrument panel. Have you tried adjusting the brightness?
Old 03-14-02, 08:03 AM
sniper5
sniper5's Avatar
dim? 2002 es has got to be the best and brightest instrument panel of any car i have been in. i love it. you may have to adjust that little wheel to the left of your steering wheel to get it lit up.
Old 03-14-02, 12:46 PM
kreativ
kreativ's Avatar
Like the rest, the only thing I can think of is the brightness control.
Brightness is fine for me, although i thought they'd be something spectacular given the way they advertise the "Optitron gauges" on the '02 ES.
By the way, the two consumer complaints registered so far with the NHSTA for the '02 ES has been:
1. Instrument panel washes out in bright sunlight
2. Gas cap too hard to remove. The dude complaining said he sprained his wrist doing it. I see a lawsuit coming up!
Old 03-14-02, 09:38 PM
i112151
i112151's Avatar
Default dim insruments only occur in bright sunlight- especially the red needle on speedo- i
i was hoping someone would know an easy solution like a brighter bulb! i've tried the brightness control with no help.
Old 03-15-02, 07:30 AM
lowPhaT
lowPhaT's Avatar
I guess you mean when it's daylight out? Well if it's light out, I don't think even the brightest bulb will really change it. You're probably having this problem basically because of the materials/colors used and the way the dash was designed.
Old 09-14-16, 12:24 PM
Artieiski
Artieiski's Avatar
Since there have been no recent posts to this blog, I was wondering if a resolution has ever been found. I also own a 2002 Avalon, and the dash lights DO NOT wash out on it. I have removed the instrument cluster from the dash and have replacement bulbs for the ES, but I cannot find where they fit into the Instrument housing. Any help would be more than appreciated.
renatodato
07-21-10 08:41 AM
lexusnb
10-23-09 02:20 AM
rodol42
11-29-05 08:01 PM
mrfixit
Automotive Care & Detailing
10-25-05 09:33 AM
nicksan
08-20-04 02:35 PM
Quick Reply: dim instrument panel on 2002 es 300
