DIY How to Change Power sterring and Alternator Belts.
Old 04-20-09, 02:17 AM
Parker Gen
Parker Gen's Avatar
Post DIY How to Change Power sterring and Alternator Belts.
Old 04-20-09, 02:57 AM
Avidstarr
Avidstarr's Avatar
thanks for the diy parkergen, will do this when needed
Old 04-20-09, 01:04 PM
Lexucan
Lexucanafer
Lexucan's Avatar
Great writeup, and great timing, PG!!
I have a belt that is a little bit squeaky and needs tightening or replacing. Now I know just how to get to it.
Old 04-20-09, 01:51 PM
llcoolpass
llcoolpass's Avatar
this diy is kinda low on info. I think I would add how to tension the belts, including the 'sterring' belt. lol :-)
peace
Old 04-20-09, 02:02 PM
mmatheny
mmatheny's Avatar
Steering pump belt - big crow bar! I just changed both belts on my '01 and didn't have to go through all this! Pretty straight forward. At least I don't have those crappy tensioners they want to put on the new cars - my buddy tried to change the belt on his daughter's Highlander, and had to take it to a mech - even HE had to use a 4 ft. cheater bar to get the darn thing to let go!
Old 04-20-09, 02:17 PM
Parker Gen
Parker Gen's Avatar
I used a foot long flat head screw driver to tension the power steering belt.
Old 04-21-09, 04:40 PM
92ES5sp
92ES5sp's Avatar
Thats how I do it. I try not reaf on the oil pan too much when doing that. Just recheck the tension after the belts get broken in; they may need to be re-adjusted again. Nice write up though. This is a similar procedure for all 1mz's, 5s-fe Gen 3 & 4 Camrys and (I think) 3mz's. Parker Gen what happened to your washer jug?
Old 04-21-09, 04:42 PM
llcoolpass
llcoolpass's Avatar
the more complicated thing is the alternator belt
i like the tensioners on cars where you loosen a tensinoer pulley nut and then turn a screw that pushed the tensioner pulley.
which is the standard on the mazdas and nissans of the 90s.
Old 04-21-09, 04:46 PM
llcoolpass
llcoolpass's Avatar
parker gen, check your ps belt, I had a 320 'prev owner put on' and the correct is 315. my tension was all the way to the end, like yours ,with the 320.
Old 04-21-09, 04:59 PM
92ES5sp
92ES5sp's Avatar
I like those too; but they break really easy if youre not careful. My favorite Toyota belts are the newer 2az Camrys and 1zz Corollas. One belt and an automatic tensioner. Pays .7 at my shop and takes about a minute. Oh hot dam this is my jam.
Old 04-21-09, 05:43 PM
llcoolpass
llcoolpass's Avatar
your'e supposed to be careful anyway since you're supposed to check the tension lol
you get more than 30 times the correct labor rate.... how come there is such a thing, you're a mechanic pirate! rofl
Old 04-21-09, 06:26 PM
92ES5sp
92ES5sp's Avatar
I mean the pulley nut gets stuck and snaps off the bolt. Maybe its a New England thing.
It depends on the job. Not everything is money. How about a cabin air for
.2!? Im outta control. Somebody help me, shes stealin my bankroll. lmfao
Old 04-21-09, 08:04 PM
mmatheny
mmatheny's Avatar
Anyway, get the new Goodyear Gatorback belts - best belts for the money.
Old 05-17-09, 03:38 PM
rlx101
rlx101's Avatar
I've done alternator on the 3rd gen. how about 4th gen es300? are they similar?
Old 05-17-09, 04:18 PM
dainfamusg
dainfamusg's Avatar
have the same problem with mine.
thanks for the DIY
Quick Reply: DIY How to Change Power sterring and Alternator Belts.
