97 ES300 IPOD set up
It can be done, but it's not easy. I installed XM satellite radio on my 93 LS and tapped into the wires which carry the CD changer inputs to the radio system. I use a relay and toggle switch to switch between CD input and XM input. The same procedure could be used to put in an aux for an ipod.
There is an extended thread on this forum explaining the steps needed to do this. The thread is in the "audio" section.
This is the link:
https://www.clublexus.com/forums/lex...oem-stereo.htm
This is the link:
here is the solution I used with my '98 ES300
http://www.soundgate.com/index.php?r...usereferrer=1&
It integrates well with the factory harness. You still get to keep your cd changer. You just have to flip a 3 position toggle switch in order to listen to your CD Changer, Ipod, or another AUX device......
Nberke
01-15-11 03:52 PM
