Replacing fog light bulbs in 2000 ES300
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Hi - I did a search and most of the threads re: fog lights appear to be about how to remove yellows from older models, or change the relay fuse so you can have them on whenever you want. My request is simple; I just want to know how to change the bulbs out before I start messing around with the belly pan and trying to reach them and then end up breaking something
I'm not the most technically inclined DIY-er. Is there an easy procedure for getting at these puppies and replacing them?
I'm also concerned for when I replace the rest of the lighting that they are a bit tough to get at...does one have to move anything out of the way to get at the front bulbs?
I asked the same question recently too, I have the 1999 ES, so it might be a bit different, but I was linked to this DIY thread.
https://www.clublexus.com/forums/es3...7-99-more.html
