Throttle Hesistation
Old 06-15-09, 10:28 PM
12340987's Avatar
Originally Posted by llcoolpass
the intake and throttle body you use a rag and spray carb cleaner
Are there rubber/plastic things in the TB or AFM that might get messed up by carb cleaner? I cleaned an actual carb with carb cleaner once and the stuff just destroys diaphrams and gaskets.
Ooh, I had a nissan that used MAFs; I wouldn't recommend touching that MAF sensor wire with anything. Maybe these toyotas are different. I guess you can trust a certifiable mechanic like coolpass.
Old 06-16-09, 11:34 PM
llcoolpass
llcoolpass's Avatar
you dont use carb cleaner on the MAF [ hot wire part ] you use what I said - I think it will be called mass air flow meter cleaner or something like that and you dont touch those wires physically
hehe
NinaMR
RX - 1st Gen (1999-2003)
05-09-09 05:31 AM
LittleMous
25
02-25-08 12:40 PM
Neil64
03-30-06 09:06 PM
sweetsc400
Performance & Maintenance
10-15-03 04:28 PM
SCmist
09-14-03 11:17 PM
Quick Reply: Throttle Hesistation
