AC Temperature Setting
I just had the air conditioner serviced and recharged on a 94 ES300. The air gets cool now, but I can not set the termerature below 66 degrees. It doesn't matter if I have the control on manuel or automatic.
Does anybody have any ideas or suggestions on how to fix this problem?
Thanks
Thanks
accontrol.pdf
This pdf descibes how to place your control unit into diagnostics. Your unit appears to have a issue, run diagnostics and let us know if you have any codes.
Thanks Guys for all your help. I will try to run a diagnostic. I thought that I could set the tempature to a number lower than 66, but maybe I am wrong.
Anyway, I just secured the owners manual today. It should tell me what the coldest setting for the AC is.
cutecboy
02-09-08 09:14 AM
