"98" es300 outside & heater temp. problem
Old 06-12-09, 01:06 PM
GEes3
GEes3's Avatar
Default "98" es300 outside & heater temp. problem
The outside temp reads 122 all the time and the heat only works if you turn it to "Hot" (above 85). I'm not sure if they are related or if they are two diffrent problems.
Old 06-12-09, 05:55 PM
GEORGE_JET
GEORGE_JET's Avatar
accontrol.pdfsounds like the sensor is open. Run the diagnostics and see if you have any codes.
Old 06-12-09, 07:38 PM
GEes3
GEes3's Avatar
just checked for codes. I have 21 with out a flash light and 00 with a flash light on the solar sensor.
Old 06-12-09, 08:44 PM
GEORGE_JET
GEORGE_JET's Avatar
Ok, try this, it shows how to test the outside sensor. I think that would be a good way to proceed.
Old 06-13-09, 09:59 PM
GEes3
GEes3's Avatar
I checked the ambient temperature sensor and found that it is bad. I have one on order, we will see if that fixes the problem. I will let you know. Thanks for your help.
Old 07-18-09, 10:05 PM
GEes3
GEes3's Avatar
The new temperature sensor fixed the problem. But just unplugging it made everything work right. Thanks again
Old 07-18-09, 11:00 PM
GEORGE_JET
GEORGE_JET's Avatar
You're welcome. My quess would be with the sensor unpluged, the controller realized that it no longer had a valid input, and bypassed it.
madouglas2
HS 250h Model (2010-2012)
06-26-17 07:35 PM
Bankswood
Performance & Maintenance
11-23-16 11:00 AM
jpv7774
07-19-15 10:32 PM
keithd60
SC- 1st Gen (1992-2000)
10-25-13 03:06 PM
IS300SGI
Maintenance
07-23-09 09:25 AM
Quick Reply: "98" es300 outside & heater temp. problem
