97 ES300 DIY for TB cleaning
Old 06-20-09, 06:19 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Default 97 ES300 DIY for TB cleaning
I did a search but it was older style ES's. Looking for a DIY for the Throttle body. I just cleaned my GS TB and MAF so i guess i should do the ES. I can tell first hand that this has not been done. Car has 114k. I've read not to use Seafoam so i already have the Carb cleaner etc..
Thanks in advance..
Tony
Old 06-21-09, 09:41 AM
tmf2004
tmf2004's Avatar
ANyone.. I did a search but no DIY? ANy info would be great.. Thanks
Old 06-22-09, 07:22 PM
BoostedE21
BoostedE21's Avatar
Why do you need a DIY? Undo, clean, redo.
Old 06-22-09, 07:25 PM
tmf2004
tmf2004's Avatar
Didn't know if it was different from the GS.. Disconnect battery, intake hose, clean TB, clean MAF, put back together
Thanks for the reply
Old 06-22-09, 07:30 PM
BoostedE21
BoostedE21's Avatar
I'm not sure if it's any different, but it's right on top so it can't be too bad. You could use this opportunity to write a DIY of your own, too.
Old 06-24-09, 04:12 PM
zajac
zajac's Avatar
Since you are cleaning the TB, you might as well take it a step further and clean out the Idle Air Control Valve that is what will make the biggest improvement. I did this last weekend and it feels like a brand new car, no more hesitation, no more problems starting when its hot out, and for some reason, no more smoke out the muffler when I first start it. One thing worth mentioning, I removed the TPS from the TB and it went to ****. There is no reason to remove it so don't because it may f#ck up on yours too. I thought my transmission was busted because when I took it out of park it felt like I got rear ended. Needless to say, after changing my pants, I bought a new TPS and all is well
Old 06-24-09, 04:23 PM
mrchacon
mrchacon's Avatar
what did u use to clean out the Idle Air Control Valve?
Old 06-24-09, 08:23 PM
ES3_Ray
ES3_Ray's Avatar
I use MAF cleaner and Intake cleaner.
i forget the brand, i know the maf is a gray (grey) spray can, and the Intake cleaner is a red bottle.
Old 06-25-09, 09:11 AM
mrchacon
mrchacon's Avatar
some one write a DIY with pictures and products
Old 06-25-09, 01:54 PM
zajac
zajac's Avatar
There is a great write up on lexusownersclub.com, it was posted by goldenstate.
Old 06-25-09, 03:29 PM
kbtr6
kbtr6's Avatar
When you guys clean the throttle body and iacv do you remove them or clean them in place?
Old 06-25-09, 07:52 PM
zajac
zajac's Avatar
Remove it, much easier.
gr8fulRed
04-07-24 10:51 AM
SC400slide
Performance & Maintenance
14
09-05-20 06:04 PM
MattyG
09-23-13 10:34 PM
BananaGS
05-29-03 07:59 AM
Quick Reply: 97 ES300 DIY for TB cleaning
