Lexus ES 300 2002
Old 06-20-09, 07:21 PM
Gedgardo
Gedgardo's Avatar
Default Lexus ES 300 2002
Tell the best way to replace the rear valve cover gasket. Thanks
Old 06-21-09, 10:21 AM
buci
buci's Avatar
Tell?
Take everything out..change the gasket..put everything back in.
Old 06-22-09, 08:44 AM
JSM1284
JSM1284's Avatar
Remove valve cover, replace gasket... There is no other way.....
Old 06-22-09, 12:54 PM
GEORGE_JET
GEORGE_JET's Avatar
Purchase a chilton or hayes manual for your car ( you can find them at most auto parts stores ). It will show you the steps that you need to take. It's not very hard, but plan on taking the better part of the day to do this.
It's also a good time to consider replacing the spark plugs if it is close to time to replace. It is much easier to replace the rear plugs when you have it all apart.
Old 06-22-09, 08:37 PM
03 ES
03 ES's Avatar
you have to remove the intake plenum...
while youre at it, id also replace the spark plugs for the rear bank and the intake plenum gasket since everything will be out anyway
LexLthr911
19
04-26-21 08:16 AM
kerno
RX - 1st Gen (1999-2003)
25
06-12-16 08:40 AM
mitmaks
06-24-12 08:13 AM
PFB
20
01-11-12 06:40 AM
nicks88
09-22-11 01:13 PM
Quick Reply: Lexus ES 300 2002
