92 es300 drivers door won't open from the outside
First off let me tell you that I have done a couple of searches and I have had no results. Please help...
I just bought my 92 es 300 used. It is in great shape and I really look forward to having it for a long time!
The main issue I am having is the driver's side outside door handle will not open the door. The inside handle works with no problems. I have already taken the door panel off and all of the clips and rods in place and not broken. It is really frustrating to have to open the door from the passenger side! Any help would be greatly appreciated! Thank you, Neal
Chances are there is a clip broken in the inside of the door handle, the outside latch has a tab with a hole inside of it on the inside of the door, there is a rod that should come from the lower part of the inside of the door and go into the hole on the inside of the handle along with a small plastic clip. that small plastic clip is usually the part that breaks.
dogwisper
SC- 1st Gen (1992-2000)
16
11-18-11 04:04 PM
