how to check if a sensor...
Old 06-24-09, 04:28 PM
mrchacon
mrchacon's Avatar
Default how to check if a sensor...
how do i check if a sensor is bad? ... ex. BRAKE sensor
Old 06-24-09, 04:33 PM
JSM1284
JSM1284's Avatar
What sensor do you need to test? And for what year and model?
Old 06-24-09, 06:21 PM
mrchacon
mrchacon's Avatar
Brake Sensor...
but how does it differ for others?
Old 06-25-09, 08:30 AM
JSM1284
JSM1284's Avatar
What brake sensor? ABS Brake sensor? Brake fluid level sensor? You have to be alot more specific.
Old 06-25-09, 09:09 AM
mrchacon
mrchacon's Avatar
well the BRAKE light on the dash is lit... i checked the brakes and they seem with plenty of pad left... i checked the fluid.. it was low... i refilled it to the full mark.. but the light is still lit... someone recommended that i check the sensor... so i suppose its the brake fluid sensor... or one that could cause the BRAKE light to be lit...
Old 06-25-09, 09:50 AM
JSM1284
JSM1284's Avatar
That would be the fluid sensor in the master cylinder resevoir. You may need to jiggle the cap a bit, sometimes the float gets stuck and doesn't turn the light off. What year is your ES?
Old 06-25-09, 12:00 PM
mrchacon
mrchacon's Avatar
98 es300 -- jiggle the cap itself or jiggle the entire resevoir?
Old 06-25-09, 06:02 PM
mrchacon
mrchacon's Avatar
bumping for jsm...! =)
Old 06-26-09, 08:44 AM
JSM1284
JSM1284's Avatar
Give the resevoir a few taps. Also, Check to make sure the parking brake is all the way released.
Old 06-26-09, 10:31 AM
eyezack87
eyezack87's Avatar
Oo, this will be helpful for me. The "BRAKE" light flashes on every time I corner
Old 06-28-09, 04:28 PM
PeterR1
PeterR1's Avatar
That happens when you're cornering on 2 wheels, eyezack.
Old 06-28-09, 10:39 PM
eyezack87
eyezack87's Avatar
I'm always on 4 haha. Never gone tripod or anything in my ES. It popped up recently too so I'm hoping what was suggested above will help. Though now it hasn't popped on for 2 days
sumrtoy
09-30-22 03:23 AM
sam12345
03-16-15 09:39 PM
targis58
RX - 1st Gen (1999-2003)
02-10-10 07:08 PM
sonbum1
13
03-01-07 07:13 PM
GSquicksilver
12-21-02 05:11 PM
Quick Reply: how to check if a sensor...
