94 to 98 convervion
94 to 98 convervion
so i dont know i think i have a 2nd gen es300 right (94)?? well on every 92-96 es i have seen the lower front bumper piece is warped alittle and it drives me crazy.. i have tried to fix it for wha i can and it aint too much better..
will a like 97 or 98 es front bumper fit my 94?? or will it match up like crap and cause a headahce and a half??
vcv10 =/= mcv20
So it might be a problem to get it to bolt on, however the 3rd gen is only half an inch wider than the 2nd gen (where exactly I have no idea). So I'm guessing with some knowledge of body work, money, and lots of time it could be done. And would probably look sexy.
How exactly do people warp their "lip" anyway? I could never figure it out. All I can think of is heat+cold or people running into snow banks or some obstacle
Mine is still perfect though hehe
Mine is fine too. I actually pulled an entire set of the metal brackets and bumper spiler from the pick and pull a few weeks back. 100% unbent. I couldn't believe it.
As for the 97-01 bumper on your 94, no. Not a chance it will fit, unless you know a lot of custom work. Different shape and size, ALL different mounting points. Won;t line up with hood or headlights. The bumper foam won;t work. I do crazy 1 off custom work, and everyone thinks it's easier then it is.
Curbs. The metal bracket that runs along the inside of the bumper directly paralle (sp?) to the black bumper spoiler gets bent. It's decently stiff metal, so it will hold the bumper in that shape.
To the OP, if you have time and skill to cut, adjust, fit, fabricate and spray than you can do it pretty easily.
brandoe91
02-23-10 07:13 PM
