View Poll Results: Which Tail Lights?
2002 Model Lights
0%
2003+ Newer Lights
18
100.00%
Voters: 18. You may not vote on this poll
Which Tail lights ?
Which Tail lights ?
I have a 2002 ES300, I see other newer ones driving around with the newer lights...I have also seen many aftermarket LED Lights, Which do you vote for?
2002 Model:
2005:
2002 Model:
2005:
you poll is not exact in the years specified: you have 2002 and 2003+, should be 2002 and 2005+
The 2005 tail lights will fit on the 2002 ES but a few connectors have to be changed and one bulb has to be omitted. It is not a 100% direct fit. The 2002 lights assembly has a black gasket around the edge as well and the 2005 does not. When mounted up, there will be a gap that the gasket would have filled. It was more than I wanted to do so instead I opted for stealth bulbs and lost the fried egg. I have about 4 or six bulbs left over if you want them.
steviej
steviej
steviej
steviej
Okay, So what exactly are the connectors that have to be changed?
Thanks...
THE PARKING LIGHT HOLDERS NEED TO BE LONGER.The tail lights fit models 2002 thru 2006.I did that to mine.I also change the shift **** and steering wheel to wood grain.
Looks Like the new ones are a clear winner, Now I just have to find some... I can't seem to, can someone help me here.
