Pics of my 93 and also another question.....
I have never posted any pictures of my car so here are two! Also it seems like i am forever having fuse issues......Now everytime i turn on my AC or heat the fuse will blow "dash etc".
What brand wheels and size on your ride? Kinda looks like Evo MR BBS' and tires on your car looks too small. Hella clean 4 a 93 man. What fuse are u exacly blowing, need to explain urself a lil more...
The tires are wayyy too small! But they are the evo bbs rims. As for the fuse
Im guessing i have another rely going bad because the air/heat will work if the car is off but once i turn the key the fuse for that which is the gauge fuse will blow.
im confused!
im confused!
So when the car is in the accerssory position the blower motor turns on. When i turn the key the fuse blows. Also i notice my fog lights aren't coming on.
Since i had the AC compression changed i have had strange fuse problems.
Unplug the connector on the compressor. Then see if the fuse blows, did you re-use the original clutch? Or did you replace the entire compressor/clutch assembly? Was the compressor new/rebuilt, or a used compressor?
I changed another rely and the fogs work...........im still dealing with the blower motor and dash lights.
Also you mentioned unlugging the compressor clutch? where would that plug be? I put the 10 amp fuse held it in place to see how long it would blow with the blower motor on. I could feel it getting hot before it eventually blew.
I am about to find a shop in my area and just write a check!
The compressor clutch is located on the front of your compressor. There should be a electrical connector within a inch or two of the compressor. Did the fuse issue start right after they replaced the compressor, or was that issue present before?
