96 Es300 - Need help with vaccum lines?
well i was changing the oil on my wifes es300 and noticed i was missing a hose on the intake manifold right after the throttle body. Right next to it theres a valve that has a plug.
I tried to find out where it went and couldn't locate where it came from also didn't see any hose just dangling around.
also i saw a hose on the charcoal cannister that was bent. but don't know where to plug the other end into?
here are some pix!
here are some pix!
That hose runs to the back of the firewall and plugs into a canister looking thing about halfway through (in front of the middle plug wire..)
I took sum pics as crappy as they may look it'll give u an idea of where it plugs into..
[IMG][/IMG]
[IMG][/IMG]
C.busta88. thanks for the picture worked out really well.
GS4 fiend. okay so that hose is supposed to go back into the intake someplace coz i couldnt see where it went. is there a way you can take a picture of it? its the hose thats closest to driverside fender right under the brake master cylinder. thanks
Vh_Supra26
15
03-01-13 11:49 AM
