Quick question: 2002 ES A/C recharge
is there anything special about a/c system on '02-04 ES's? i recharged a/c in our '95 ES before, is it just the same? I got one of those recharging kits with the pressure gauge.
thanks!
thanks!
well i hooked up the refill kit to the low port and according to the pressure gauge its at 45psi so the system is full... hmmm. i do not want to overfill it.
also i noticed that the system has green dye in it already. Previous owner maintained the car at the dealer. Another thing I noticed - next to the high port there is a little transparent window built in line where you can see refrigirant cycling. What is it for??
If the freon pressure is fine what else can this be? any tests i can do before taking it to the mechanic?
the cabin air filter was replaced recently. the fan does come on and i will check the fins.
I stuck the food grade thermometer into the a/c vent in the cabin and turned a/c on to the max cold. the temp went down to 62'F eventually (outside 87'F) but when its really hot (above 95'F) the a/c seems to struggle cooling..
It should be doing better than that, my converted 93 is able to maintain 70 deg, easy with a ambient temp 100 and change. When you checked the pressure, were you slightly above idle? Say 1200 rpm or so.
I hope you guys are checking the Temp., inside the cabin. Because when I put a Electric temp. gauge in the vent I get 40'F, with temp outside in the High 90's.and that's on medium speed.If you guys are getting temp., of 60's&70's with gauge inside the ac vent something is not right.94 LS400, over 100,000 miles. rix 101 you are right do not overfill; it will not cool properly.Also, I drive in HOT New Mexico.
Steve300h
ES - 7th Gen (2019-present)
02-11-19 05:59 PM
