Leak in radiator can get into transmission fluid?? PLease HElp!!!
Hey i noticed that my coolant in the reservoir went from between full and low to bellow low... so then i added some water since i didnt have and coolant... so went to a local mechanic and he said it might a leak in my radiator. The mechanic said that the internal leak is flowing into my transmission, because when he checked my transmission fluid,he noticed signs of sediments of water getting mixed with the transmission fluid... So i have a few questions...
1. Is it possible that the leak can get into the transmission?
2. And if so how urgent is it that i need to replace the radiator? if it is that...
Any help would be highly appreciated...
Thanks
Thanks
Thanks guys...
Do u know of anywhere i can get a radiator for cheap? i was thinking about going to the junk yard... what do u think?? Would that be wise to do?
Thanks again!!
Thanks again!!
jayjw
10-01-04 06:49 PM
antifreeze, camry, coolant, drive, fluid, internal, leak, leaking, put, radiator, reservoir, tranamission, tranny, transmission, water
