Grinding/Buzzing noise when trying to crank under 50deg F.
I have done quite a bit of research so far on this one but i cant find a solution. My '95 ES300 makes a grinding/loud buzzing noise from the engine area when i first try to crank it in the morning when its under 50F. When i turn the key to on, i have full power to electronics, no hesitation at all, then i try to crank it makes a very loud buzzing noise. It does not happen at all when its over 50-60 degrees.
After it grinds for about 5 seconds it cranks and fires. Then runs fine. No check engine light. Unless the car is dead cold, it will not happen again. I cant figure out if its the battery.. the starter, or something else? I had this problem last winter, and now its getting cold again (im in NJ) and im getting the problem again. Any ideas, or anything i can do to diagnose this? I brought it to a mechanic and he said he has to hear it, the problem it, he would have to have the car there overnight, because it will only do it once, in the morning. Any help is appreciated!!
Based on more research, i think I've narrowed it down to: The starter solenoid-the starter-or the flywheel. Im not too sure on how to diagnose any of these. Nor the difficulty of removing the starter, disassembling it, and understanding the condition of it and its gears. One thing i dont understand is why the cold would affect the starter system. Anyway, any help would be appreciated because im afraid i might be stripping gears. Thanks.
Based on more research, I think I've narrowed it down to The starter solenoid-the starter-or the flywheel. I'm not too sure how to diagnose any of these. Nor the difficulty of removing the starter, disassembling it, and understanding the condition of it and its gears. One thing I don't understand is why the cold would affect the starter system. Anyway, any help would be appreciated because im afraid I might be stripping gears. Thanks.
SPhoto
35
06-07-11 01:04 AM
FireCode
Performance & Maintenance
02-06-05 12:15 PM
