98 es300 with codes p1133, p1135, p1153, p1155
It all began with a check engine light with code PO125 = Coolant Temp Sensor.
I replaced that sensor, cleared the codes a few days later I am now getting codes:
P1133
Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 1 Sensor 1)
P1135
Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P1153
Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 2 Sensor 1)
P1155
I do not understand why both O2 sensors would fail at the same time. Is there something else I am missing upstream that is causing the 02 sensors to report malfunctions? I have checked for vacuum leaks, checked coolant level, checked all connections.... Please help!!
P1133
P1135
P1153
P1155
George,
Thank you for the feedback. I located both the relay and the fuse. The fuse looks good but is there a way to test the relay? Or Would I be better off to just order another in case?
Thanks!
Thanks!
You could check to see if the same relay is used for the EFI or ac and swap them. To check for operation, I suggest taking a short section of speaker wire, and stripping back bot ends. Then you could remove the relay, slip the wire into the proper plug, and re-install the relay. These type of electical problems can be caused by several things, it can take a little while to figure out which one is the issue.
P1133
P1135
P1153
P1155
P1133
P1135
P1153
P1155
Do you have any useful information pertaining to this topic?
Yes, he did. But you appear to be too thin-skinned and thick-headed to "get" it. There's no reason to snipe back like that when someone is trying to help.
By reviving a long-dead thread from a long-gone member, you really achieve nothing, and the people with technical knowledge to share get dragged through a dead issue unless they carefully scan dates to keep from going down that rabbit-hole.
Better to start a fresh thread with your specific issues, and also look at toyota sites with the same engine and PCU logic/build.
OP is a 1 post wonder :-)
Any how, I had crazy error readings like this and found allot of wires frayed or shorted at the connectors. I found good connectors at the yard and re-spliced them. it cleared all the codes on it's own. Never came back. Just a thought.
It's not a dead issue for me. I understand that it is an old thread, but I have scoured the internet and found no solution. I have spent a lot of time on the issue and at this point anything is worth a shot. I am neither thin skinned or thick headed. I was pointing out that he was wasting his time by commenting on something with no useful information, and doing exactly what he was so against, commenting on a thread and keeping it alive.
SlowRider1
18
03-29-16 02:53 PM
