99 ES300 rear bearing replacement - $53 30 MINUTES!
Just FYI I had a rear wheel bearing go out. The dealer quoted $500 for the whole job.
A new bearing was anywhere from $50 to $75. That did not include the cost of removing the hub, remove the old bearing, etc...
I found a hub-bearing assembly that included the entire assembly (including the lug nuts). It was $53 (included shipping) from AM-autoparts. It is an unbolt, bolt on process and took 30 minutes. Only special tool was a torque wrench .
hsiehd
12-07-12 09:18 AM
