overtightened axle nut/busted something
![Thumbs down](https://www.clublexus.com/forums/images/icons/icon13.gif)
my brother overtightened the passenger-side axle nut on an es300 3.0 and a couple of seconds later we heard a popping noise. Started the car up and the tranny wouldn't shift and was making a loud vibrating noise. Any guesses as to what it might be? And is this something we could fix with the tranny still in the vehicle? P.S. The axle was still all the way in the tranny after this happened, so we ruled it out.
If the axle is busted, I would strongly recommend not putting it into gear. That vibration and noise is probably something else getting busted up. It is a fairly straight forward job to change a axle in these cars, you can purchase a rebuilt axle at most auto parts stores, (of course they will not accept the old axle for a core, considering that it is damaged). I believe the actual torque value is 217 ft lbs
yeah i got some autozone axle.... can't beat life time warranty... =P
anywho... there's a possibility that the axle wasn't put on correctly... if you put it in drive and it doesn't move.. its not completely in.
and if it is completely in and it makes sounds at certain speed... your axle is just crapped out.
