Lexus ES300
Old 11-10-09, 04:28 PM
kelley5795
kelley5795's Avatar
Default Lexus ES300
Where dose the crank seņor connect to the wireing huness or how does it route? I'm can't find it anywhere and I would love some help
Old 11-10-09, 05:24 PM
GEORGE_JET
GEORGE_JET's Avatar
You forgot to mention what year you car was. For the mid 90's at least (just quessing what you have). It is located right behind the harmonic balancer. In order to gain acess to it, I would remove the passenger side wheel, and then the inner fender shield. At this point you will be looking directly at the harmonic balancer. The sensor is at app the 2 o'clock position.
Old 11-10-09, 05:30 PM
kelley5795
kelley5795's Avatar
Its a 1993 but I don't see it and I have the harmonic balance r off and the AC and almost the timing cover, nothing yet, is this Eng the same as a Toyota Camry 1993?
Old 11-10-09, 06:02 PM
GEORGE_JET
GEORGE_JET's Avatar
93 are obdI engine, the crankshaft and camshaft position sensors are both built into the distributor.
Old 11-10-09, 06:04 PM
kelley5795
kelley5795's Avatar
Okay But i still cant find it, any other pointers you could tell me?:, videos?-
Old 11-10-09, 06:49 PM
GEORGE_JET
GEORGE_JET's Avatar
93 dist.doc
Here's what I could find on it, hope it helps. The sensor is built into the dist, it is not clear which of the two are for the crankshaft, What code are you getting? I may be able to give you some pointers on what to look for.
Old 11-10-09, 07:14 PM
kelley5795
kelley5795's Avatar
Okay can you tell me this, the harness that has the Alternator, heating sensor that harness has the crank sensor cord right? i guess what i really need to know is that 3rd connector on that harness connect to the cranksensor?
Old 11-10-09, 07:15 PM
kelley5795
kelley5795's Avatar
Where does it run? behind the AC near the timing belt?
Old 11-10-09, 07:31 PM
GEORGE_JET
GEORGE_JET's Avatar
It's on the other side of the engine, by the throttle body, air intake.
Old 11-10-09, 07:33 PM
kelley5795
kelley5795's Avatar
ok its a small 2 PIN white connector
Old 11-10-09, 08:02 PM
GEORGE_JET
GEORGE_JET's Avatar
93 dis schem.doc
This shows a little more detail, the connector that you are interested in is the dist connector,.
Old 11-10-09, 08:28 PM
kelley5795
kelley5795's Avatar
is the crank sensor wired up tho the timing cover up to the knock sensor??
Old 11-10-09, 09:14 PM
kelley5795
kelley5795's Avatar
These are the connectors and the white one is the one I'm trying to connect to the car and i think its the crank but maybe its dif
Attached Thumbnails Lexus ES300-dsc05792.jpg   Lexus ES300-dsc05793.jpg   Lexus ES300-dsc05794.jpg   Lexus ES300-dsc05795.jpg   Lexus ES300-dsc05796.jpg
Old 11-10-09, 09:46 PM
GEORGE_JET
GEORGE_JET's Avatar
The white connector looks like it is to the water temp sensor (brown plug by the timming cover). I believe that is the ecm water temp sensor (ecm uses a different sensor than the instrament panel). The crank sensor is in the distributor, (on the drivers side of the engine).
Old 11-10-09, 09:52 PM
BoostedE21
BoostedE21's Avatar
Kelley -
I don't mean to sound rude, but it would really help if you could use a more descriptive thread title next time. A lot of people who might be able to solve your issue will probably just completely pass over this thread, because they can't tell what problems you're having by the extremely generic thread title.
Quick Reply: Lexus ES300
