Please Help me Identify
Old 12-28-09, 12:01 PM
frohboy33
frohboy33's Avatar
Default Please Help me Identify
When looking at the engine from the passengers side, below and to the left of the timing belt cover there is a wire that goes to a plug there. The wire is blue and black(but has black wrapping around it). I found that mine has been cut in half. Anybody know what this is?
Old 12-28-09, 12:14 PM
angmedic91
angmedic91's Avatar
FYI, bro, but your going to have to give year and model of your car and maybe even a picture so the guys on here can help you out. And welcome to CL. I dont know to much about engines, but have learned alot from the others on here. We are all here to help and learn from each other.
Old 12-28-09, 12:27 PM
frohboy33
frohboy33's Avatar
Sorry about that, I guess I was to excited to submit my first post.
I dont have a pic at the moment.
Its a 2001 ES300 with 71500 miles on it.
Old 12-28-09, 12:45 PM
frohboy33
frohboy33's Avatar
Not the best picture, but its the best quality I could do with the cellphone.
[IMG]ftp://cis.bismarckstate.edu/frohlich/122809133.jpg[/IMG]
Old 12-28-09, 01:45 PM
JSM1284
JSM1284's Avatar
Link no worky
Old 12-28-09, 01:46 PM
JSM1284
JSM1284's Avatar
Got it to work, Changed the URL
Is it just one single wire in that cover. Black with a blue stripe?
Old 12-28-09, 01:52 PM
frohboy33
frohboy33's Avatar
Yes it is. Only 1 wire. The plug says 11468 on it.
Old 12-28-09, 01:57 PM
JSM1284
JSM1284's Avatar
Can you get a better pic of what the plug plugs into, hard telling from the pic.
Old 12-28-09, 02:05 PM
frohboy33
frohboy33's Avatar
i can't at the moment, but will try later.
Right below it is a power steering hose and to the left thats the firewall. Not sure if that helps, but I'll seee if I cant get a better pic
JSM1284
JSM1284's Avatar
From what I CAN see, looks like the Power steering pressure switch. Is the component it plugs into on the power steering pump, or line?
Those shiny aluminum lines are AC lines.
Old 12-28-09, 02:17 PM
frohboy33
frohboy33's Avatar
I don't think it is, but its hard to tell because of where its located. At least it doesn't look like the pictures of those switches when I google them. Thanks for looking.
Old 12-28-09, 03:16 PM
frohboy33
frohboy33's Avatar
Is it possible its the Oil Pressure switch?
Old 12-28-09, 04:01 PM
JSM1284
JSM1284's Avatar
The oil pressure switch is located in front of the timing cover near the alternator i believe.
Old 12-28-09, 04:42 PM
llcoolpass
llcoolpass's Avatar
my best guess is your PCV hose and PCV valve
a better picture with an arrow on it would be a great help to those helping you ....please
Old 12-29-09, 07:31 AM
frohboy33
frohboy33's Avatar
JSM1284 You were correct. Thank you very much. Its the Power Steering Pressure Switch. I tested by turning the wheel at idle and the RPM's did not bump up, instead they dropped. I believe this is the function of that switch, to bump up the RPM's when turning the wheel. Is it vital that I replace it?
Quick Reply: Please Help me Identify
