p1135 code 1999 lexus es300
hi all,
my car is giving me code p1135 which i found out that this corresponds to A/f ratio sensor B1S1, which is located in the back of the engine before the cat. my problem is that i need help determining which sensor to buy as there are many types and don't want to get the wrong one. i went to amazon.com which has the best prices plus free shipping. i looked at the following but i'm not sure which one is the correct:
Denso 234-4622 Oxygen Sensor $70
Denso 234-9009 Air and Fuel Sensor $120
Bosch 15217 Oxygen Sensor, OE Type Fitment $101
please help me in making the correct choice.
get the one that is for bank 1 sensor 1, upstream its also called.
but, getting an 02 sensor just because you have a code for it is not 100% correct decision. you also shouldn't just replace one, but both upstream right now.
PLEASE NOTE!!!!!!!!!!!!!!!!
O2 and AF are two DIFFERENT types of sensors, and can NOT be switched.
The AF sensor from the dealer is around $55 more then the O2 sensor. If your near Stamford, CT, I may be able to get the sensor from the dealer for around $175 for you if you get it.
asg14 thx for the offer, but unfortunaly i'm in NY. do you know if the Denso 234-9009 Air and Fuel Sensor is the right sensor for Bank 1 sensor 1 code p1135? i just want to get rid of the engine light.
Rbeeber
12-02-18 08:42 PM
JRabs
11-01-09 07:39 AM
