HUGE PROBLEM 97 es300
Was installing a deck. Plugged everything in. it worked. so today i was finishing all the wireing and now theres no power to the deck. At first i thought it was the deck itself. So i plugged in my stock head unit and there was no power to there as well. I checked the fuses and they were good. Need help on this.
I might be wrong, but I've been told that if your using the OEM harness from the amp, then the amp is feeding power to the head unit and the speakers. If that is the case, you might have a problem with your OEM amp, might of fried it somehow. Must people going with an aftermarket head unit go with an after market amp and then tap into the speaker wire harness at where it plugs into the OEM amp to send the signal from the aftermarket amp to the speakers.
I'm always scared that my soundsystem is going to blow something everytime I turn it up high. At night, my headlights damn near turn off when the bass hits hard.
dieselpb
10-27-16 01:02 PM
es300freq
04-24-13 12:27 PM
es300freq
02-20-09 04:16 PM
