93 es300 cap wire order
can someone show the plug order for the distributor cap in a 3vz-fe? is this correct?
I suspect my plug wires don't match this car and are therefore way out of order. Where can I get proper ones? Rockauto has a Bosch set for $40
Yes it is correct. I would suggest turning the engine over to TDC and making sure that the distributor rotor is pointing at #1, or 180 deg oposite since you appear to have some concerns about it. Also cylinder # 1 is on the rear bank, passenger side.
I am not trying to sound like a jerk, but are you sure that you are looking at the right cylinders? The bank close to the firewall has #1 #3 #5. The one next to the rad is #2 #4 #6. It has been a long time since I have personnelly removed my distributor, but I believe that it can only go in one of two ways. My first guess would be that you are confused on what the cyl numbering is.
wire harness
i need help ... i have a sc300 with engne 1jzvvti turbo , i need the wire harness or diagram please and someone know where i can find the airflow meter...
mario, please FOADYFM
123, your wires should be numbered for which cylinder they go to and the cap is correctly numbered. just check it. there's nothing anyone on this forum can do for you.
why do you suspect the wires are wrong, you didn't say that part. but just check the spark plug wires are plugged in to the proper spot
nevermind, it looks like it was hooked up right.
I thought the firing order was out of cylinder order, like 162534. This cap didn't fit my car.
surfing
03-23-17 04:03 PM
lexuss01
10-05-09 07:20 PM
saltyreefs
04-19-06 10:28 PM
