1999 ES300 Horns
Hi. New to the forum. I've searched but have not found an answer to my questions. Just acquired a 1999 ES300 with 62,000 miles from an elderly lady. It's had some front end repair work done. When I went to get it safety inspected it sounds like only one horn is working. I see one horn right in front of the radiator, but can not locate another horn. Are there two (or more) horns on this car? Is so, where are they located? Thanks. Greg
yeah, you gonna have to remove the all of that to get to the horn, it attach right on behind the fender, remember to take out the rocket arms and side of the bumper before you go ahead and take the fender apart.
Shouldn't it pass inspection even with one horn?
Alternatively you could consider buying a horn and mounting it somewhere in an easy place under the hood. You should be able to wire it in parallel with the existing good horn.
Just a thought.
Phil
Just a thought.
Phil
Thank you all, well, I've GS 2012 original horns, I would like to fix them on the same location on my ES without any new wiring .. I prefer to keep every thing original.
But its seems that the other horn location little bit difficult any way thank you very much.
Guys, I found the second horn, I removed front right tail light + FR headlamp, the horn is fixed their, and replaced with the new Lexus horn, its great! just plug & play.
